下載 mariadb10.3
docker pull mariadb:10.3
下載 haproxy1.7.9
docker pull haproxy:alpine
haproxy設定檔
vi /home/docker/haproxy/conf/haproxy.cfg
global chroot /usr/local daemon nbproc 1 group nobody user nobody #pidfile /opt/haproxy/logs/haproxy.pid ulimit-n 65536 #spread-checks 5m #stats timeout 5m #stats maxconn 100 ########預設配置############ defaults mode tcp retries 3 #兩次連接失敗就認為是伺服器不可用,也可以通過後面設置 option redispatch #當serverId對應的伺服器掛掉後,強制定向到其他健康的伺服器 option abortonclose #當伺服器負載很高的時候,自動結束掉當前佇列處理比較久的連結 maxconn 32000 #默認的最大連接數 timeout connect 5000ms #連接逾時 timeout client 30000ms #用戶端超時 timeout server 30000ms #伺服器超時 #timeout check 2000 #心跳檢測超時 log 127.0.0.1 local0 err #[err warning info debug] ########MariaDB配置################# listen mariadb bind 0.0.0.0:3306 mode tcp balance roundrobin server s1 192.168.1.38:3307 weight 1 maxconn 10000 check inter 10s server s2 192.168.1.38:3308 weight 1 maxconn 10000 check inter 10s server s3 192.168.1.38:3309 weight 1 maxconn 10000 check inter 10s
vi /etc/hosts
127.0.0.1 localhost localhost.localdomain localhost4 localhost 127.0.0.1 DKnetw 127.0.0.1 localhost 127.0.0.1 DKnetw.localdomain4.localdomain4 ::1 localhost localhost.localdomain localhost6 localhost6.localdomain6 192.168.1.43 zabbix.tony 192.168.1.38 docker.tony 192.168.1.38 mariadb-0 192.168.1.38 mariadb-1 192.168.1.38 mariadb-2
建立docker執行目錄
docker
├── haproxy
│ └── conf
│ └── haproxy.cfg
└── mariadb
├── cluster0
│ ├── conf
│ └── data
├── cluster1
│ ├── conf
│ └── data
└── cluster2
├── conf
└── data
mkdir /home/docker/mariadb/cluster0/ mkdir /home/docker/mariadb/cluster0/conf mkdir /home/docker/mariadb/cluster0/data mkdir /home/docker/mariadb/cluster1/ mkdir /home/docker/mariadb/cluster1/conf mkdir /home/docker/mariadb/cluster1/data mkdir /home/docker/mariadb/cluster2/ mkdir /home/docker/mariadb/cluster2/data mkdir /home/docker/mariadb/cluster2/conf
Cluster0設定檔
Cluster0/server.cnf設定檔 先注釋掉 wsrep_cluster_address,因為要初始化用戶之後再開始集群
vi /home/docker/mariadb/cluster0/conf/server.cnf
[server] [mysqld] server_id=130 pid-file=/var/run/mysqld/mysqld.pid socket=/var/run/mysqld/mysqld.sock basedir=/usr datadir=/var/lib/mysql tmpdir=/tmp user=mysql skip-external-locking skip-name-resolve character-set-server=utf8 port=3306 # # localhost which is more compatible and is not less secure. #bind-address = 127.0.0.1 [server] [mysqld] server_id=130 pid-file=/var/run/mysqld/mysqld.pid socket=/var/run/mysqld/mysqld.sock basedir=/usr datadir=/var/lib/mysql tmpdir=/tmp user=mysql skip-external-locking skip-name-resolve character-set-server=utf8 port=3306 # # Instead of skip-networking the default is now to listen only on # localhost which is more compatible and is not less secure. #bind-address = 127.0.0.1 # # * Fine Tuning # max_connections=1000 connect_timeout=5 wait_timeout=600 max_allowed_packet=100M thread_cache_size=128 sort_buffer_size=4M bulk_insert_buffer_size =16M tmp_table_size=32M max_heap_table_size =32M [galera] wsrep_causal_reads=ON #節點應用完事務才返回查詢請求 wsrep_provider_options="gcache.size=128M"#同步複製緩衝集區 wsrep_certify_nonPK=ON #為沒有顯式申明主鍵的表生成一個用於certificationtest的主鍵,默認為ON #log-bin=/app/galera/mysql-bin #如果不接從庫,注釋掉 #log_slave_updates=1 #如果不接從庫,注釋掉 query_cache_size=0 #關閉查詢緩存 wsrep_on=ON #開啟全同步複製模式 wsrep_provider=/usr/lib/galera/libgalera_smm.so #galera library wsrep_cluster_name=MariaDB-Galera-Cluster #wsrep_cluster_address="gcomm://192.168.1.38:4567,192.168.1.38:4568,192.168.1.38:4569" #galera cluster URL wsrep_node_name=mariadb-0 #wsrep_node_address=172.18.0.4 wsrep_sst_auth=syncuser:syncuser #wsrep_sst_method=xtrabackup-v2 wsrep_sst_method=rsync binlog_format=row default_storage_engine=InnoDB innodb_autoinc_lock_mode=2 #主鍵自增模式修改為交叉模式 wsrep_slave_threads=8 #開啟並行複製執行緒,根據CPU核數設置 innodb_flush_log_at_trx_commit=0 #事務提交每隔1秒刷盤 innodb_buffer_pool_size=2G [embedded] [mariadb] [mariadb-10.3]
Cluster1設定檔差異部分
vi /home/docker/mariadb/cluster1/conf/server.cnf
wsrep_node_name=mariadb-1
Cluster2設定檔差異部分
vi /home/docker/mariadb/cluster2/conf/server.cnf
wsrep_node_name=mariadb-2
啟動第一個節點
docker run -d --name mariadb-cluster0 --expose 4567 -p 4567:4567 -p 3307:3306 -e TIMEZONE=Asia/Taipei -v /home/docker/mariadb/cluster0/conf:/etc/mysql/conf.d -v /home/docker/mariadb/cluster0/data:/var/lib/mysql -e MYSQL_ALLOW_EMPTY_PASSWORD=yse mariadb:10.3
進容器加用戶
docker exec -it mariadb-cluster0 /bin/bash
mysql -uroot -p
GRANT ALL PRIVILEGES ON *.* TO 'root'@'%'IDENTIFIED BY '' WITH GRANT OPTION; GRANT ALL PRIVILEGES ON *.* TO 'syncuser'@'%'IDENTIFIED BY 'syncuser' WITH GRANT OPTION; flush privileges; shutdown;
第二個節點,重復以上加用戶的操作
docker run -d --name mariadb-cluster1 --expose 4567 -p 4568:4567 -p 3308:3306 -e TIMEZONE=Asia/Taipei -v /home/docker/mariadb/cluster1/conf:/etc/mysql/conf.d -v /home/docker/mariadb/cluster1/data:/var/lib/mysql -e MYSQL_ALLOW_EMPTY_PASSWORD=yse mariadb:10.3
docker exec -it mariadb-cluster1 /bin/bash
mysql -uroot -p
第三個節點,一樣重復以上加用戶的操作
docker run -d --name mariadb-cluster2 --expose 4567 -p 4569:4567 -p 3309:3306 -e TIMEZONE=Asia/Taipei -v /home/docker/mariadb/cluster2/conf:/etc/mysql/conf.d -v /home/docker/mariadb/cluster2/data:/var/lib/mysql -e MYSQL_ALLOW_EMPTY_PASSWORD=yse mariadb:10.3
docker exec -it mariadb-cluster2 /bin/bash
mysql -uroot -p
停止以及刪除所有以運行的容器
docker stop $(docker ps -a -q) docker rm $(docker ps -a -q)
編輯設定檔 解開wsrep_cluster_address注釋,再次啟動3個節點 --wsrep-new-cluster 只有在第一次集群,第一個節點,才需要加上,下次啟動不需要此參數
vi /home/docker/mariadb/cluster0/conf/server.cnf vi /home/docker/mariadb/cluster1/conf/server.cnf vi /home/docker/mariadb/cluster2/conf/server.cnf
啟動集群
cluster0
docker run --name mariadb-cluster0 --expose 4567 -p 4567:4567 -p 3307:3306 -v /home/docker/mariadb/cluster0/conf:/etc/mysql/conf.d -v /home/docker/mariadb/cluster0/data:/var/lib/mysql mariadb:10.3 --wsrep-new-cluster
cluster1
docker run --name mariadb-cluster1 --expose 4567 -p 4568:4567 -p 3308:3306 -v /home/docker/mariadb/cluster1/conf:/etc/mysql/conf.d -v /home/docker/mariadb/cluster1/data:/var/lib/mysql mariadb:10.3
cluster2
docker run --name mariadb-cluster2 --expose 4567 -p 4569:4567 -p 3309:3306 -v /home/docker/mariadb/cluster2/conf:/etc/mysql/conf.d -v /home/docker/mariadb/cluster2/data:/var/lib/mysql mariadb:10.3
haproxy
docker run -d --restart=always --name haproxy --expose 3366 -p 3366:3306 -v /home/docker/haproxy/conf:/usr/local/etc/haproxy:ro haproxy:alpine
連進haproxy
mysql -uroot -p -h192.168.1.38 -P 3366
查看SHOW STATUS LIKE 'wsrep_cluster_size';
