← 返回上一頁
Linux/Unix
centos yum update出現Error: autofs conflicts with cyrus-sasl-lib
⚠ 本文最後更新於 2013-02-16(13 年前),部分內容可能已過時。
yum update失敗問題解決
運行#yum update
出現以下錯誤
--> Processing Conflict: autofs conflicts cyrus-sasl-lib < 2.1.22-5.el5_4.3
--> Finished Dependency Resolution
1:autofs-5.0.1-0.rc2.143.el5_6.2.i386 from update has depsolving problems
--> autofs conflicts with cyrus-sasl-lib
selinux-policy-devel-2.4.6-300.el5_6.1.noarch from update has depsolving problems
--> Missing Dependency: checkpolicy >= 1.33.1-5 is needed by package selinux-policy-de
lvm2-2.02.74-5.el5_6.1.i386 from update has depsolving problems
--> Missing Dependency: device-mapper >= 1.02.55-2 is needed by package lvm2-2.02.74-5
Error: Missing Dependency: checkpolicy >= 1.33.1-5 is needed by package selinux-policy-d
Error: Missing Dependency: device-mapper >= 1.02.55-2 is needed by package lvm2-2.02.74-
You could try using 1。--skip-broken to work around the problem
You could try running: 2。package-cleanup --problems
3。package-cleanup --dupes
4。rpm -Va --nofiles --nodigest
金色字告訴我們可以用 2 3 4來查看問題原因
[root@rh5 Server]# package-cleanup --dupes
Setting up yum
Repository base is listed more than once in the configuration
Repository dag is listed more than once in the configuration
[root@rh5 Server]# package-cleanup --problems
Setting up yum
Reading local RPM database
Processing all local requires
No problems found
當終端顯示Repository base is listed more than once in the configuration:
它告訴我們有個定義重複了:
觀察/etc/yum.repos/裡面的文件和/etc/yum.cof,[base] [dag]這些如果重複定義了,會報此錯。
將重複刪除,問題解決
再次運行#package-cleanup --problems不出現Repository base is listed more than once in the configuration:的時候
運行#yum update --skip-broken
update成功!
要是有以下提示
warning: rpmts_HdrFromFdno: Header V3 DSA signature: NOKEY, key ID 37017186
Public key for postgresql-libs-8.1.11-1.el5_1.1.i386.rpm is not installed
只需用下面方法將簽名重新導入一次即可。
rpm --import /etc/pki/rpm-gpg/RPM-GPG-KEY-redhat-release
分享這篇
在〈“centos yum update出現Error: autofs conflicts with cyrus-sasl-lib”〉中有 1 則留言
  1. Yum更新進行了很長一段時間後,就會發生錯誤。↓!
     1:autofs-5.0.1-0.rc2.143.el5_5.6.i386 from updates has depsolving problems
     You could try using --skip-broken to work around the problem
     You could try running: package-cleanup --problems
    yum clearn all執行後還是有衝突請執行以下指令
     # yum install yum-utils
     #package-cleanup --dupes
     #package-cleanup --cleandupes
     # yum-complete-transaction
    再更新看看是否正常
