一. Glusterfs建置
| hostname | ip | glusterfs peer |
| k8s-master | 192.168.1.156 | no |
| k8s-node1 | 192.168.1.14 | yes |
| k8s-node2 | 192.168.1.15 | yes |
| k8s-node3 | 192.168.1.7 | yes |
在k8s-node1,k8s-node2,k8s-node3 從ESXI上額外在掛一顆硬碟(不需格式化及掛載)
#Brick Server 三個節點需要保持時鐘同步
# yum install chrony -y
# egrep -v "^$|^#" /etc/chrony.conf
server 172.20.0.252 iburst
driftfile /var/lib/chrony/ drift
makestep 1.0 3
實時同步
logdir / var / log / chrony
#設置開機啟動,並重啟
# systemctl enable chronyd.service
# systemctl restart chronyd.service
#查看狀態
# systemctl status chronyd.service
# chronyc sources -v
"_port_comment": "Heketi Server Port Number",
"port": "8080",
"_use_auth": "Enable JWT authorization. Please enable for deployment",
"use_auth": false,
"_jwt": "Private keys for access",
"jwt": {
"_admin": "Admin has access to all APIs",
"admin": {
"key": "admin@123"
"_user": "User only has access to /volumes endpoint",
"user": {
"key": "admin@123"
"_glusterfs_comment": "GlusterFS Configuration",
"glusterfs": {
"_executor_comment": [
"Execute plugin. Possible choices: mock, ssh",
"mock: This setting is used for testing and development.",
" It will not send commands to any node.",
"ssh: This setting will notify Heketi to ssh to the nodes.",
" It will need the values in sshexec to be configured.",
"kubernetes: Communicate with GlusterFS containers over",
" Kubernetes exec api."
"executor": "ssh",
"_sshexec_comment": "SSH username and private key file information",
"sshexec": {
"keyfile": "/etc/heketi/heketi_key",
"user": "root",
"port": "22",
"fstab": "/etc/fstab"
"_kubeexec_comment": "Kubernetes configuration",
"kubeexec": {
"host" :"https://kubernetes.host:8443",
"cert" : "/path/to/crt.file",
"insecure": false,
"user": "kubernetes username",
"password": "password for kubernetes user",
"namespace": "OpenShift project or Kubernetes namespace",
"fstab": "Optional: Specify fstab file on node. Default is /etc/fstab"
"_db_comment": "Database file name",
"db": "/var/lib/heketi/heketi.db",
"_loglevel_comment": [
"Set log level. Choices are:",
" none, critical, error, warning, info, debug",
"Default is warning"
"loglevel" : "debug"
"clusters": [
"nodes": [
"node": {
"hostnames": {
"manage": [
"192.168.1.14"
"storage": [
"192.168.1.14"
"zone": 1
"devices": [
"/dev/sdc"
"node": {
"hostnames": {
"manage": [
"192.168.1.15"
"storage": [
"192.168.1.15"
"zone": 1
"devices": [
"/dev/sdc"
"node": {
"hostnames": {
"manage": [
"192.168.1.7"
"storage": [
"192.168.1.7"
"zone": 1
"devices": [
"/dev/sdc"
apiVersion: v1 kind: Secret metadata: name: heketi-secret namespace: default data: # base64 encoded password. Eg: echo -n "mypassword" | base64 key: YWRtaW5AMTIz type: kubernetes.io/glusterfs
apiVersion: storage.k8s.io/v1 kind: StorageClass metadata: name: gluster-heketi-storageclass provisioner: kubernetes.io/glusterfs reclaimPolicy: Delete parameters: resturl: "http://192.168.1.156:8080" restauthenabled: "true" restuser: "admin" secretNamespace: "default" secretName: "heketi-secret" volumetype: "replicate:2" allowVolumeExpansion: true
IsDefaultClass: No
Annotations: kubectl.kubernetes.io/last-applied-configuration={"allowVolumeExpansion":true,"apiVersion":"storage.k8s.io/v1","kind":"StorageClass","metadata":{"annotations":{},"name":"gluster-heketi-storageclass"},"parameters":{"restauthenabled":"true","resturl":"http://192.168.1.156:8080","restuser":"admin","secretName":"heketi-secret","secretNamespace":"default","volumetype":"replicate:2"},"provisioner":"kubernetes.io/glusterfs","reclaimPolicy":"Delete"}
Provisioner: kubernetes.io/glusterfs
Parameters: restauthenabled=true,resturl=http://192.168.1.156:8080,restuser=admin,secretName=heketi-secret,secretNamespace=default,volumetype=replicate:2
AllowVolumeExpansion: True
MountOptions: <none>
ReclaimPolicy: Delete
VolumeBindingMode: Immediate
Events: <none>
kind: PersistentVolumeClaim
apiVersion: v1
namespace: default
annotations:
volume.beta.kubernetes.io/storage-class: "gluster-heketi-storageclass"
spec:
accessModes:
- ReadWriteMany
resources:
requests:
storage: 2Gi
