環境
一鍵部署ELK環境,適用於:
系統:CentOS 7.X
ELK版本:7.XX
前置條件
jdk:
yum -y install java-1.8.0-openjdk.x86_64
所有安裝包路徑:/root/InstallELKB-Shell/
腳本
elk.sh
#!/usr/bin/env bash
# ****************************Elasticsearch Deplay Script****************** ************************************
 clear
# ELK版本號
VER=7.XX
ESIP=`ip addr | grep "inet" | grep -v "127.0.0.1" | grep -v "inet6" | awk -F/ '{print $1}' | awk '{print $2}' `
echo -e "\033[32m ########################################## ################################### \033[0m"
echo -e "\033[32m # Auto Install ELK. ## \033[0m"
echo -e "\033[32m # Press Ctrl + C to cancel ## \033[0m"
echo -e "\033[32m # Any key to continue ## \033[ 0m"
echo -e "\033[32m # Softwae:elasticsearch- ${VER} /logstash- ${VER} /filebeat- ${VER} /kibana- ${VER}    ## \033[0m"
echo -e"\033[32m ############################################# ################################ \033[0m"
Read_Input () {
 echo -e "\033[32m Please Input You Kibana Pass Key IP: \033[0m"
read -p "Please Input You HOST Pass Key IP:[192.168.10.55]" KibanaIP
 read -p "Please Input You HOST Pass Key IP: Password:" KibanaPass
echo -e "\033[32m Please Input You Filebeat Pass Key IP: \033[0m"
read -p "Please Input You HOST Pass Key IP:[192.168.10.56]" FilebeatIP
read -p "Please Input You HOST Pass Key IP: Password:" FilebeatPass
Init_Yumsource()
{ if ! ping -c2 www.baidu.com &>/dev/null then echo "您無法上外網,不能配置yum源" exit fi echo "配置阿里雲yum源" if [ ! -d / etc/yum.repos.d/backup ]; then         	mkdir /etc/yum.repos.d/backup 		mv /etc/yum.repos.d/* /etc/yum.repos.d/backup 2>/dev/null	 		curl -o /etc/yum.repos.d/CentOS-Base.repo https://mirrors.aliyun.com/repo/Centos-7.repo &>/dev/null     	curl -o /etc/yum.repos. d/epel.repo http://mirrors.aliyun.com/repo/epel-7.repo &>/dev/null fi }
 Init_Hostname()
  hostnamectl set -hostname elk-1 echo " $ESIP elk-1" >> /etc/hosts	 }
 Init_SElinux()
{ echo "關閉防火牆" 	systemctl stop firewalld 	systemctl disable firewalld echo "關閉selinux" 	setenforce 0 	sed -ri '/^SELINUX=/ s/enforcing/disabled/'   /etc /selinux/config echo "解決sshd遠程連接慢的問題" 	sed -ri '/^GSSAPIAu/ s/yes/no/' /etc/ssh/sshd_config 	sed -ri '/^#UseDNS/ {s/^#/ /;s/yes/no/}' /etc/ssh/sshd_config 	systemctl enable sshd crond &> /dev/null }
 Create_UserLogFile()
  groupadd elk
  useradd elk -g elk
  mkdir -pv /data/elk/{data,logs}
  chown -R elk:elk /data/
Unpackaged_Authorization()
  yum -y install ntpdate
  tar xvf /root/InstallELKB-Shell/elasticsearch- ${VER} -linux-x86_64.tar.gz -C /opt/
  chown -R elk:elk /opt/elasticsearch- ${ VER} /
  ntpdate -b ntp1.aliyun.com
 Set_System_Parameter()
cat >> /etc/security/limits.conf <<EOF
* soft nproc 2048
* hard nproc 4096
* soft nofile 65536
* hard nofile 131072
EOF
echo  "vm.max_map_count = 262144" >> /etc/sysctl.conf && sysctl -p
cat >> /etc/profile <<EOF
export HISTTIMEFORMAT= "%Y-%m-%d %H:%M:%S "
 EOF
source /etc/profile
cat >> /opt/elasticsearch- ${VER} /config/elasticsearch.yml <<EOF
cluster.name: elk
node.name: node-1
bootstrap.memory_lock: false
 path.data: /data/elk/data
path. logs: /data/elk/logs
network.host: 0.0.0.0
http.port: 9200
discovery.seed_hosts: [ "elk-1" ]
cluster.initial_master_nodes: [ "node-1" ]
EOF
runuser -l elk -c " /bin/bash /opt/elasticsearch- ${VER} /bin/elasticsearch " &> /opt/elasticsearch.log &
Test_Service()
  esport=`ss -antp |grep :::9200 | awk -F::: '{print $2}' ` if [ $esport -eq 9200 ]; then echo -e   "\033[32m Elasticsearch is OK... \033[0m " fi }
# **********************PublicKeyKibana************************** ************************************************** **
PublicKeyKibana()
if [ ! -f /usr/bin/expect ]; then
 	yum -y install expect
fi
 sed -i 's/# *StrictHostKeyChecking *ask/StrictHostKeyChecking no/g' /etc/ssh/ssh_config
systemctl restart sshd
cd /root/.ssh/
ssh-keygen -t rsa -N '' -f id_rsa -q
if [ $? -eq 0 ]; then
 /usr/bin/expect <<-EOF
set timeout 10
spawn ssh-copy- id $KibanaIP
 expect { "yes/no" { send "yes\r" ; exp_continue } "password:" { send " $KibanaPass \r" } } expect eof EOF fi
# **********************Kibana Deploy Script************************ ********************************************
 Install_Kibana()
echo  $ ESIP > /root/InstallELKB-Shell/ESIP.txt
scp /root/InstallELKB-Shell/kibana- ${VER} -linux-x86_64.tar.gz $KibanaIP :
scp /root/InstallELKB-Shell/ESIP.txt $KibanaIP :
scp /root/InstallELKB-Shell/InstallKibana.sh $KibanaIP :
ssh root@ $KibanaIP  '
bash /root/InstallKibana.sh '
# *******************************************Filebeat Deploy Script*** ************************************************
 PublicFilebeat( )
fi
cd / root/.ssh/
rm -rf /root/.ssh/*
set timeout 10
spawn ssh-copy-id $FilebeatIP
    "yes\r" ; exp_continue } "password:" { send " $FilebeatPass \r" } } expect eof EOF fi }
Install_Filebeat()
  scp /root/InstallELKB-Shell/filebeat- ${VER} -x86_64.rpm   $FilebeatIP :
  scp /root/InstallELKB-Shell/InstallFilebeat.sh $FilebeatIP :
  ssh root@ $FilebeatIP  'bash /root/InstallFilebeat .sh'
 	scp /root/InstallELKB-Shell/filebeat.yml $FilebeatIP :/etc/filebeat/
  ssh root@ $FilebeatIP  'systemctl restart filebeat && systemctl disable filebeat && rm -rf /root/InstallFilebeat.sh'
# ********************************************Logstash**** ************************************************** ************
 Install_logstash()
  tar xvf /root/InstallELKB-Shell/logstash- ${VER} .tar.gz -C /opt/
  cp /root/InstallELKB-Shell/nginx. yml /opt/logstash- ${VER} /
  /opt/logstash- ${VER} /bin/logstash -f /opt/logstash- ${VER} /nginx.yml &>/opt/logstash.log &
ES-StartUp_SelfStart()
cat >> /etc/init.d/elasticsearch.sh <<EOF
nohup runuser -l elk -c "" /bin/bash /opt/elasticsearch- ${VER} /bin/elasticsearch " &
nohup /opt/logstash- ${VER} /bin/logstash -f /opt/nginx.yml &
EOF
  echo " /etc/init.d/elasticsearch.sh " >> /etc/rc.d/rc.local
  chmod +x /etc/init.d/elasticsearch.sh
  chmod +x /etc/rc.d/rc.local
main() {
#######Elasticsearch#######
Read_Input
Init_Yumsource
Init_Hostname
Init_SElinux
Create_UserLogFile
Test_Service
#########Kibana###########
PublicKeyKibana
Install_Kibana
########Filebeat#########
PublicFilebeat
Install_Filebeat
Kibana-StartUp_SelfStart
#######Logstash#########
Install_logstash
main
InstallKibana.sh
#!/usr/bin/env bash
# ELK版本號
VER=7.XX
elastip=$(cat /root/ESIP.txt )
if [ ! -d /opt/kibana- ${VER} -linux-x86_64 ]; then
 	tar xvf /root/kibana- $ {VER} -linux-x86_64.tar.gz -C /opt/
fi
init_yumsource()
then echo "您無法上外網,不能配置yum源" exit fi echo "配置阿里雲yum源" if [ ! -d / etc/yum.repos.d/backup ]; then mkdir /etc/yum.repos.d/backup 	mv /etc/yum.repos.d/* /etc/yum.repos.d/backup 2>/dev/null 	curl -o curl -o /etc/yum.repos.d/CentOS-Base.repo https://mirrors.aliyun.com/repo/Centos-7.repo &>/dev/null 	curl -o /etc/yum .repos.d/epel.repo http://mirrors.aliyun.com/repo/epel-7.repo &>/dev/null 	yum -y install ntpdate     ntpdate -b ntp1.aliyun.com fi }
 init_SElinux()
{ echo "關閉防火牆" 	systemctl stop firewalld 	systemctl disable firewalld echo "關閉selinux" 	setenforce 0 	sed -ri '/^SELINUX=/ s/enforcing/disabled/'   /etc/selinux/config echo "解決sshd遠程連接慢的問題" 	sed -ri '/^GSSAPIAu/ s/yes/no/' /etc/ssh/sshd_config 	sed -ri '/^#UseDNS/ {s/^#//;s/yes/no/}' /etc/ssh/sshd_config 	systemctl enable sshd crond &> /dev/null }
 SetKibanaParameter()
cat >> /opt/kibana- ${VER} -linux-x86_64/config/kibana.yml <<EOF
server.host: "0.0.0.0"
 server.port: 5601
elasticsearch.hosts: [ "http :// $elastip :9200" ]
EOF
 StartKibana()
  /opt/kibana- ${VER} -linux-x86_64/bin/kibana --allow-root &>/opt/kibana.log &
Test_Service()
  KibanaPort=` ss -antp | grep 5601 | awk '{print $4}' | awk -F*: '{print $NF}' ` if [ $KibanaPort -eq 5601 ]; then echo -e   "\ 033[32m Kibana is OK... \033[0m " fi }
DeleteUselessFiles()
  rm -rf /root/kibana- ${VER} -linux-x86_64.tar.gz
  rm -rf /root/InstallKibana.sh
  rm -rf /root/ESIP.txt
Kibana-StartUp_SelfStart()
{ echo "nohup /opt/kibana- ${VER} -linux-x86_64/bin/kibana --allow-root &" >> /etc/init.d/kibana.sh echo "/bin/ bash /etc/init.d/kibana.sh" >> /etc/rc.local         chmod +x /etc/init.d/kibana.sh         chmod +x /etc/rc.local }
init_SElinux
SetKibanaParameter
StartKibana
Test_Service
DeleteUselessFiles
InstallFilebeat.sh
#!/usr/bin/env bash
# ELK版本號
VER=7.XX
Init_Yumsource()
{ if ! ping -c2 www.baidu.com &>/dev/null then echo "您無法上外網,不能配置yum源" exit fi echo "配置阿里雲yum源" if [ ! -d / etc/yum.repos.d/backup ]; then         mkdir /etc/yum.repos.d/backup         mv /etc/yum.repos.d/* /etc/yum.repos.d/backup 2>/dev/null         curl -o /etc/yum.repos.d/CentOS-Base.repo https://mirrors.aliyun.com/repo/Centos-7.repo &>/dev/null         curl -o /etc/yum.repos. d/epel.repo http://mirrors.aliyun.com/repo/epel-7.repo &>/dev/null 	    yum -y install ntpdate 	    ntpdate -b ntp1.aliyun.com fi }
Init_SElinux()
{ echo "關閉防火牆" 	systemctl stop firewalld 	systemctl disable firewalld echo "關閉selinux" 	setenforce 0 	sed -i '/^SELINUX=/ s/enforcing/disabled/'   /etc/selinux/config echo "解決sshd遠程連接慢的問題" 	sed -i '/^GSSAPIAu/ s/yes/no/' /etc/ssh/sshd_config 	sed -i '/^#UseDNS/ {s/^#//;s/yes/no/}' /etc/ssh/sshd_config 	systemctl enable sshd crond &> /dev/null }
Install_Filebeat()
  rpm -ivh /root/filebeat- ${VER} -x86_64.rpm
  rm -rf /root/filebeat- ${VER} -x86_64.rpm
Init_Yumsource
Init_SElinux
Install_Filebeat
來源網址:https://k8sdev.com/2019/11/01/ELK%EF%BC%9A%E4%B8%80%E9%94%AE%E9%83%A8%E7%BD%B2/
Hits: 33
