安裝所須套件
apt install software-properties-common add-apt-repository universe apt update apt install curl composer fping git graphviz imagemagick mariadb-client mariadb-server mtr-tiny nginx-full nmap php7.2-cli php7.2-curl php7.2-fpm php7.2-gd php7.2-json php7.2-mbstring php7.2-mysql php7.2-snmp php7.2-xml php7.2-zip python-memcache python-mysqldb rrdtool snmp snmpd whois *mbstring
安裝與設定 LibreNMS
useradd librenms -d /opt/librenms -M -r usermod -a -G librenms www-data cd /opt git clone https://github.com/librenms/librenms.git chown -R librenms:librenms /opt/librenms chmod 770 /opt/librenms setfacl -d -m g::rwx /opt/librenms/rrd /opt/librenms/logs /opt/librenms/bootstrap/cache/ /opt/librenms/storage/ setfacl -R -m g::rwx /opt/librenms/rrd /opt/librenms/logs /opt/librenms/bootstrap/cache/ /opt/librenms/storage/
安裝 PHP 相關套件
su - librenms ./scripts/composer_wrapper.php install --no-dev exit
資料庫與帳號建立
systemctl restart mysql mysql -uroot -p CREATE DATABASE librenms CHARACTER SET utf8 COLLATE utf8_unicode_ci; CREATE USER 'librenms'@'localhost' IDENTIFIED BY 'password'; GRANT ALL PRIVILEGES ON librenms.* TO 'librenms'@'localhost'; FLUSH PRIVILEGES; exit
修改設定檔 (/etc/mysql/mariadb.conf.d/50-server.cnf)
# 找到 [mysqld] 區段加入下列 innodb_file_per_table=1 lower_case_table_names=0 # 改完退出編輯器重啟服務 systemctl restart mysql
設定網頁伺服器 (/etc/php/7.2/fpm/php.ini,請依據的版本找到對應路徑,本文以 7.2 為例)
# 設定正確時區 date.timezone = Asia/Taipei # 改完退出編輯器重啟服務 systemctl restart php7.2-fpm
設定 Nginx 站台 (/etc/nginx/conf.d/librenms.conf)
# 以下設定貼上後存檔 server { listen 80; server_name librenms.example.com; root /opt/librenms/html; index index.php; charset utf-8; gzip on; gzip_types text/css application/javascript text/javascript application/x-javascript image/svg+xml text/plain text/xsd text/xsl text/xml image/x-icon; location / { try_files $uri $uri/ /index.php?$query_string; } location /api/v0 { try_files $uri $uri/ /api_v0.php?$query_string; } location ~ \.php { include fastcgi.conf; fastcgi_split_path_info ^(.+\.php)(/.+)$; fastcgi_pass unix:/var/run/php/php7.2-fpm.sock; } location ~ /\.ht { deny all; } } # 改完退出編輯器重啟服務 rm /etc/nginx/sites-enabled/default systemctl restart nginx
設定 SNMP 服務
cp /opt/librenms/snmpd.conf.example /etc/snmp/snmpd.conf curl -o /usr/bin/distro https://raw.githubusercontent.com/librenms/librenms-agent/master/snmp/distro chmod +x /usr/bin/distro systemctl restart snmpd
設定排程作業
cp /opt/librenms/librenms.nonroot.cron /etc/cron.d/librenms cp /opt/librenms/misc/librenms.logrotate /etc/logrotate.d/librenms
檔案權限調整
chown -R librenms:librenms /opt/librenms setfacl -d -m g::rwx /opt/librenms/rrd /opt/librenms/logs /opt/librenms/bootstrap/cache/ /opt/librenms/storage/ setfacl -R -m g::rwx /opt/librenms/rrd /opt/librenms/logs /opt/librenms/bootstrap/cache/ /opt/librenms/storage/
安裝流程
參考文章
https://ithelp.ithome.com.tw/articles/10224076
https://www.ichiayi.com/wiki/tech/librenms
Hits: 469
