安裝docker--centos6
yum install -y yum-utils \
device-mapper-persistent-data lvm2
yum install http://mirrors.yun-idc.com/epel/6/i386/epel-release-6-8.noarch.rpm
sudo yum install docker-io
安裝docker--centos6
service docker start
chkconfig docker on
安裝docker-ubuntu
移除舊版本
apt-get remove docker docker-engine docker.io -y
apt-get autoremove -y
apt-get purge -y
安裝相關工具
apt-get update
apt-get install curl -y
apt-get install inux-image-extra-$(uname -r)
apt-get install linux-image-extra-virtual
apt-get install apt-transport-https ca-certificates software
apt-get install apt-transport-https ca-certificates software-properties-common -y
下載並新增APT儲存庫憑證
curl -fsSL https://download.docker.com/linux/ubuntu/gpg |sudo apt-key add -
檢查APT儲存庫憑證
sudo apt-key finger 0EBFCD88
新增docker儲存庫到儲存庫清單
sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu stable"
vim /etc/apt/sources.list
deb [arch=amd64] https://download.docker.com/linux/ubuntu xenial stable
# deb-src [arch=amd64] https://download.docker.com/linux/ubuntu xenial stable
sudo tail -2 /etc/apt/sources.list
更新APT儲存庫
sudo apt update
安裝docker ce 版本
apt-get install docker-ce -y
查看docker版本
docker version
