官方網站
mydns http://mydns.bboy.net/
MyDNS-ng http://www.mydns-ng.com/
mydnsconfig: MyDNSConfig Homepag
安裝環境 Centos6.8 64bit MariaDB10.1 PHP5.5.16 Apache2.2.27 mydns-1.2.8.31 MyDNSConfig-3.0.1 or MyDNSConfig-1.1.0
請先安裝好LAMP環境
1.安裝mydns
cd /usr/local/src tar -zxvf mydns-1.2.8.31.tar.gz cd mydns-1.2.8.31 ./configure --prefix=/usr/local/mydns --with-mysql-lib=/usr/lib64/mysql --with-zlib=/usr/lib64 make; make install
編譯過程如遇到configure: error: No supported database found. Either MySQL or PostgreSQL is required.
請確認是否有/usr/lib64/mysql/libmysqlclient.so 這支檔案
chmod 755 /usr/lib64/libmysqlclient.so.15
ln -s /usr/lib64/libmysqlclient.so.15 /usr/lib64/mysql/libmysqlclient.so
ln -s /usr/lib64/libmysqlclient_r.so.15 /usr/lib64/mysql/libmysqlclient_r.so
重新載入ldconfig
ldconfig
拷貝設定檔到/etc底下
cp /root/mydns-1.2.8.31/mydns.conf /etc/
建立啟動腳本
vi /etc/init.d/mydns
#### #! /bin/sh # mydns Start the MyDNS server # Author: Falko Timme <>. # chkconfig: - 80 75 # description: mydns set -e PATH=/usr/local/mydns/sbin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin NAME=mydns DAEMON=/usr/local/mydns/sbin/$NAME DESC="MyDNS Server" SCRIPTNAME=/etc/init.d/$NAME # Gracefully exit if the package has been removed. test -x $DAEMON || exit 0 case "$1" in start) echo -n "Starting $DESC: $NAME" $DAEMON --background echo "." ;; stop) echo "Stopping $DESC: $NAME." kill -9 `pidof $NAME` &> /dev/null ;; restart) echo "Restarting $DESC: $NAME." $0 stop && sleep 1 $0 start ;; *) echo "Usage: $SCRIPTNAME {start|stop|restart}" >&2 exit 1 ;; esac exit 0 ####
2.安裝MyDNSConfig-3.0.1
下載
tar -zxvf MyDNSConfig-3.0.1.tar.gz
cd mydnsconfig/install
編譯 ./lib/install.lib.php 找到以下這段
if(stristr($content,'CentOS release 5.2 (Final)')) { $distname = 'CentOS'; $distver = '5.2'; $distid = 'centos52'; $distbaseid = 'fedora'; swriteln("Operating System: CentOS 5.2 or compatible\n"); }
更改為你的os版本
if(stristr($content,'CentOS release 6.8 (Final)')) { $distname = 'CentOS'; $distver = '6.8'; $distid = 'centos52'; ## 此處不要改 $distbaseid = 'fedora'; swriteln("Operating System: CentOS 6.8 or compatible\n");
不改安裝時會出現以下錯誤
PHP Notice: Undefined variable: distver in /tmp/ispconfig3_install/install/lib/install.lib.php on line 135 PHP Notice: Undefined variable: distid in /tmp/ispconfig3_install/install/lib/install.lib.php on line 135 PHP Notice: Undefined variable: distbaseid in /tmp/ispconfig3_install/install/lib/install.lib.php on line 35 Linux Distribution of Version not recognized.
執行安裝腳本
cd /root/mydnsconfig/install
php -q install
設定資料庫
預設管理port 為8080 也可以設定80
MyDNSConfig Port [8080]
設定軟連接
ln -s /var/www/ispconfig /usr/local/ispconfig/interface/web
安裝完畢後會自動寫入apache設定檔及mydns設定檔
注意:/etc/mydns.conf設定檔中為 soa-table = dns_soa、rr-table = dns_rr
啟動mydns服務
/etc/init.d/mydns start
[root@mariadb ~]# /etc/init.d/mydns start Starting MyDNS Server: mydns
設定apache vhost設定
<VirtualHost *:80> ServerAdmin root@localhost DocumentRoot /usr/local/ispconfig/interface/web ServerName mydns.hack.idv.tw ErrorLog logs/mydns.err CustomLog logs/mydns.acc common </VirtualHost>
開啟網頁 預設帳號為admin /admin
測試解析正常
