安裝前準備
sudo apt-get update
sudo apt-get upgrade
安裝套件
sudo apt-get install squirrelmail
squirrelmail-locales 各國語系
squirrelmail-lockout 登入失太多次鎖定某段時間,不讓其登入,以避免密碼字典攻擊
squirrelmail-logger 操作記錄
複製一份virtual host設定檔到apache底下
sudo cp /etc/squirrelmail/apache.conf /etc/apache2/sites-available/squirrelmail.conf
編輯squirrelmail.conf
vi /etc/apache2/sites-available/squirrelmail.conf
Alias /squirrelmail /usr/share/squirrelmail
<Directory /usr/share/squirrelmail>
  Options FollowSymLinks
  <IfModule mod_php5.c>
    php_flag register_globals off
  </IfModule>
  <IfModule mod_dir.c>
    DirectoryIndex index.php
  </IfModule>
  # access to configtest is limited by default to prevent information leak
  <Files configtest.php>
    order deny,allow
    deny from all
    allow from 127.0.0.1
  </Files>
</Directory>
# users will prefer a simple URL like http://webmail.example.com
<VirtualHost *:80>
  DocumentRoot /usr/share/squirrelmail
  ServerName squirrelmail.example.com
</VirtualHost>
# redirect to https when available (thanks [email protected])
#  Note: There are multiple ways to do this, and which one is suitable for
#  your site's configuration depends. Consult the apache documentation if
#  you're unsure, as this example might not work everywhere.
#<IfModule mod_rewrite.c>
#  <IfModule mod_ssl.c>
#    <Location /squirrelmail>
#      RewriteEngine on
#      RewriteCond %{HTTPS} !^on$ [NC]
#      RewriteRule . https://%{HTTP_HOST}%{REQUEST_URI}  [L]
#    </Location>
#  </IfModule>
#</IfModule>
將設定好的virtual host軟連結一份到/etc/apache2/sites-enables/
sudo ln -s /etc/apache2/sites-available/squirrelmail /etc/apache2/sites-enabled/
重新啟動apache2
sudo service apache2 reload
開啟瀏覽器 輸入
http://yourip/squirrelmail
SquirrelMail
設定squirrelmail的相關參數
1.直接編輯/etc/squirrelmail/config.php
2.使用內建的組態編輯器sudo squirrelmail-configure
SquirrelMail-1
設定Server Settings 按下2 可以設定server的相關參數
外掛安裝
將下載好的外掛放在/usr/share/squirrelmail/plugins
/usr/share/squirrelmail/config
./conf.pl
squirrelmail1
輸入Available Plugins可用的外掛數字
squirrelmail2
返回主選單記得按s存檔
squirrelmail3
後台Option就會看到新增的外掛項目
squirrelmail4
首頁登入畫面
SquirrelMail-2
參考文章
https://www.linode.com/docs/email/clients/installing-squirrelmail-on-ubuntu-12-04
http://myip.tw/itsmw/index.php?title=SquirrelMail
