安裝vpn是比較麻煩和頭疼的事情,因此分享一個一鍵安裝vpn腳本,Centos下測試通過:
yum remove -y pptpd ppp
iptables --flush POSTROUTING --table nat
iptables --flush FORWARD
rm -rf /etc/pptpd.conf
rm -rf /etc/ppp
wget http://poptop.sourceforge.net/yum/stable/packages/dkms-2.0.17.5-1.noarch.rpm
wget http://poptop.sourceforge.net/yum/stable/packages/kernel_ppp_mppe-1.0.2-3dkms.noarch.rpm
wget http://poptop.sourceforge.net/yum/stable/packages/pptpd-1.3.4-2.rhel5.i386.rpm
wget http://poptop.sourceforge.net/yum/stable/rhel5Server/i386/ppp-2.4.4-14.1.rhel5.i386.rpm
yum -y install make libpcap iptables gcc-c++ logrotate tar cpio perl pam tcp_wrappers
rpm -ivh dkms-2.0.17.5-1.noarch.rpm
rpm -ivh kernel_ppp_mppe-1.0.2-3dkms.noarch.rpm
rpm -qa kernel_ppp_mppe
rpm -Uvh ppp-2.4.4-14.1.rhel5.i386.rpm
rpm -ivh pptpd-1.3.4-2.rhel5.i386.rpm
mknod /dev/ppp c 108 0
echo 1 > /proc/sys/net/ipv4/ip_forward
echo "mknod /dev/ppp c 108 0" >> /etc/rc.local
echo "echo 1 > /proc/sys/net/ipv4/ip_forward" >> /etc/rc.local
echo "localip 172.16.36.1" >> /etc/pptpd.conf
echo "remoteip 172.16.36.2-254" >> /etc/pptpd.conf
echo "ms-dns 8.8.8.8" >> /etc/ppp/options.pptpd
echo "ms-dns 8.8.4.4" >> /etc/ppp/options.pptpd
pass=`openssl rand 6 -base64`
if [ "$1" != "" ]
then pass=$1
fi
echo "vpn pptpd ${pass} *" >> /etc/ppp/chap-secrets
iptables -t nat -A POSTROUTING -s 172.16.36.0/24 -j SNAT --to-source `ifconfig  | grep 'inet addr:'| grep -v '127.0.0.1' | cut -d: -f2 | awk 'NR==1 { print $1}'`
iptables -A FORWARD -p tcp --syn -s 172.16.36.0/24 -j TCPMSS --set-mss 1356
service iptables save
chkconfig iptables on
chkconfig pptpd on
service iptables start
service pptpd start
echo "VPN service is installed, your VPN username is vpn, VPN password is ${pass}"
