Nginx - Red Hat Init Script
這支script適用於Redhat, Centos, Fedora
#vi /etc/init.d/nginx
內容如下
#!/bin/sh
# nginx - this script starts and stops the nginx daemon
# chkconfig: - 85 15
# description: Nginx is an HTTP(S) server, HTTP(S) reverse \
# proxy and IMAP/POP3 proxy server
# processname: nginx
# config: /etc/nginx/nginx.conf
# config: /etc/sysconfig/nginx
# pidfile: /var/run/nginx.pid
# Source function library.
. /etc/rc.d/init.d/functions
# Source networking configuration.
. /etc/sysconfig/network
# Check that networking is up.
[ "$NETWORKING" = "no" ] && exit 0
nginx="/usr/local/nginx/sbin/nginx" //nginx 所在路徑
prog=$(basename $nginx)
NGINX_CONF_FILE="/usr/local/nginx/conf/nginx.conf" //設定檔所在路徑
[ -f /etc/sysconfig/nginx ] && . /etc/sysconfig/nginx
lockfile=/var/lock/subsys/nginx
make_dirs() {
# make required directories
user=`nginx -V 2>&1 | grep "configure arguments:" | sed 's/[^*]*--user=\([^ ]*\).*/\1/g' -`
options=`$nginx -V 2>&1 | grep 'configure arguments:'`
for opt in $options; do
if [ `echo $opt | grep '.*-temp-path'` ]; then
value=`echo $opt | cut -d "=" -f 2`
if [ ! -d "$value" ]; then
# echo "creating" $value
mkdir -p $value && chown -R $user $value
fi
fi
done
start() {
[ -x $nginx ] || exit 5
[ -f $NGINX_CONF_FILE ] || exit 6
make_dirs
echo -n $"Starting $prog: "
daemon $nginx -c $NGINX_CONF_FILE
retval=$?
echo
[ $retval -eq 0 ] && touch $lockfile
return $retval
stop() {
echo -n $"Stopping $prog: "
killproc $prog -QUIT
retval=$?
echo
[ $retval -eq 0 ] && rm -f $lockfile
return $retval
restart() {
configtest || return $?
stop
sleep 1
start
reload() {
echo -n $"Reloading $prog: "
killproc $nginx -HUP
RETVAL=$?
echo
force_reload() {
restart
configtest() {
$nginx -t -c $NGINX_CONF_FILE
rh_status() {
status $prog
rh_status_q() {
rh_status >/dev/null 2>&1
case "$1" in
start)
rh_status_q && exit 0
$1
stop)
rh_status_q || exit 0
$1
restart|configtest)
$1
reload)
rh_status_q || exit 7
$1
force-reload)
force_reload
status)
rh_status
condrestart|try-restart)
echo $"Usage: $0 {start|stop|status|restart|condrestart|try-restart|reload|force-reload|configtest}"
exit 2
esac
#chmod +x /etc/init.d/nginx
#chkconfig --add nginx
#chkconfig nginx on
#service nginx start //nginx startup
ps. [root@test auto]# service nginx
Usage: /etc/init.d/nginx {start|stop|status|restart|condrestart|try-restart|reload|force-reload|configtest}
