方式1.官方Gitlab image啟動gitlab
sudo docker run --detach \
   --hostname gitlab.example.com \
   --publish 443:443 --publish 80:80 \
   --name gitlab \
   --restart always \
   --volume /gitlab/config:/etc/gitlab \
   --volume /gitlab/logs:/var/log/gitlab \
   --volume /gitlab/data:/var/opt/gitlab \
   gitlab/gitlab-ce:latest
進入容器
sudo docker exec -it gitlab /bin/bash
方式2.docker-compose啟動
version: '3.2'
services:
  gitlab:
    image: gitlab/gitlab-ce:latest
    hostname: gitlab.example.com
    container_name: gitlab
    restart: always
    volumes:
      - /gitlab/config:/etc/gitlab
      - /gitlab/logs:/var/log/gitlab
      - /gitlab/data:/var/opt/gitlab
    ports:
      - 443:443
      - 80:80
    environment:
      GITLAB_OMNIBUS_CONFIG: |
        gitlab_rails['smtp_enable'] = true
        gitlab_rails['smtp_address'] = "smtp.gmail.com"
        gitlab_rails['smtp_port'] = 587
        gitlab_rails['smtp_user_name'] = "[email protected]"
        gitlab_rails['smtp_password'] = "xxx"
        gitlab_rails['smtp_domain'] = "smtp.gmail.com"
        gitlab_rails['smtp_authentication'] = "login"
        gitlab_rails['smtp_enable_starttls_auto'] = true
        gitlab_rails['smtp_tls'] = false
        gitlab_rails['smtp_openssl_verify_mode'] = 'peer'
    networks:
      - devel-net
    logging:
      driver: "json-file"
      options:
        max-size: "10m"
        max-file: "3"
networks:
  devel-net:
docker-compose up -d
