#!/bin/bash
#wget http://jaist.dl.sourceforge.net/project/zabbix/ZABBIX%20Latest%20Stable/2.2.3/zabbix-2.2.3.tar.gz
tar zxf zabbix-2.2.3.tar.gz
cd zabbix-2.2.3
./configure --prefix=/usr/local/zabbix --enable-agent
make install
#執行完上面命令,在/usr/local/sbin目錄下會生成zabbix_agent、zabbix_agentd、zabbix_get、zabbix_sender四個檔。
mkdir /etc/zabbix
#追加zabbix agentd用戶
groupadd zabbix ;useradd -g zabbix -s /sbin/nologin zabbix
#設定檔和啟動腳本
#mkdir /etc/zabbix
#vim /usr/local/zabbix/etc/zabbix_agentd.conf
#設定/usr/local/zabbix/etc/zabbix_agentd.conf檔,修改下面幾個地方:
sed -i 's/^Server=127.0.0.1/Server=192.168.85.225/g' /usr/local/zabbix/etc/zabbix_agentd.conf
#Server=127.0.0.1 ← ZABBIX伺服器的IP地址
#sed -i 's/^Hostname=Zabbix server/Hostname=/g' /usr/local/zabbix/etc/zabbix_agentd.conf
#Hostname=localhost ← ZABBIX agentd的host名字
#ListenIP=127.0.0.1 ← ListenIP位址(要與監視物件伺服器上設定的一樣)
#PidFile=/var/run/zabbix/zabbix_agentd.pid LogFile=/var/log/zabbix/zabbix_agentd.log
#新建zabbix的pid檔和log檔的目錄
#mkdir /var/run/zabbix
#mkdir /var/log/zabbix #chown zabbix:zabbix /var/run/zabbix #chown zabbix:zabbix /var/log/zabbix
#啟動腳本設定
cp misc/init.d/fedora/core/zabbix_agentd /etc/init.d/
sed -i "s#BASEDIR=/usr/local#BASEDIR=/usr/local/zabbix#g" /etc/init.d/zabbix_agentd
ln -s /usr/local/zabbix/etc /etc/zabbix
ln -s /usr/local/zabbix/bin/* /usr/bin/
ln -s /usr/local/zabbix/sbin/* /usr/sbin/
cat >> /etc/services <<end
zabbix-agent 10050/tcp   #Zabbix Agent
zabbix-agent 10050/udp   #Zabbix Agent
zabbix-trapper 10051/tcp #Zabbix Trapper
zabbix-trapper 10051/udp #Zabbix Trappe
end
#賦予啟動腳本許可權
chmod 755 /etc/init.d/zabbix_agentd
#啟動
sed -i 's/^Hostname=Zabbix server/Hostname=192.168.85.222/g' /usr/local/zabbix/etc/zabbix_agentd.conf
/etc/init.d/zabbix_agentd start
#設置該啟動腳本為守候service
chkconfig zabbix_agentd on
#OK
Hits: 93
